It is currently Thu Aug 14, 2025 3:37 am
 Post subject: Side Marker Dots
PostPosted: Sat Oct 24, 2015 4:03 pm
Over the 15 years I've been messing around with this stuff I have tried all sorts of ways to jig up for side dots but have always just gone back to free handing them after marking the locations. I usually install them after the fretboard is on and leveled just before fretting.
Here is a little trick that works pretty well for that. I usually try to put them all the same distance from the top edge of the fretboard. I like the way that looks. My edges usually come out to around .2" so I measure .1" down from the top. I found that if I wrap some tape around the ruler at the 1" mark thick enough to register on the fretboard edge it makes it easy to get that .1" mark consistent. I mark it with a sharp awl.
These users thanked the author Terence Kennedy for the post (total 3): cablepuller1 (Mon Oct 26, 2015 4:40 pm) • Alex Kleon (Sat Oct 24, 2015 5:26 pm) • jack (Sat Oct 24, 2015 4:51 pm)
 Post subject: Re: Side Marker Dots
PostPosted: Sat Oct 24, 2015 5:47 pm
First name: Ringo
Nice tip! To go one step further, even with a good mark made with a center punch I always had trouble getting the holes drilled straight in with no wandering because of the curvature of the fretboard. Then one day I thought to put a little fence up on my drill press like this. Whether the fretboard's on or off the neck, this makes it infinitely easier to get the drill bit straight into the board right on the mark.
PostPosted: Sat Oct 24, 2015 6:11 pm
Agreed it can be a pita --- here's one of our fixtures. Its designed for a drill press. I did plan to use hardened drill bushings but the hard Maple has held up well. After each session we drizzle a little thin CA in the holes.
Ken Cierp
PostPosted: Sat Oct 24, 2015 6:36 pm
First name: Tom
Last Name: West
State: Nova Scotia
As Terence has done away with jigs, so have I. I just center in two directions, mark with an awl and drill with a hand driven jewelers drill. I find this for me to be the easiest and most accurate.
Tom
PostPosted: Sat Oct 24, 2015 9:39 pm
That's slick.
I have something like this but on an individual hole basis. Here it is. I have holes for 1/16"and 3/32" set. It's a piece of aluminum angle with a piece of birch plywood screwed to it. I just mark out the dot locations on the top of the board and clamp the jig in place and use my hand drill. This way (Like Ken's) they're all registered the same distance off the bottom of the fretboard.
PostPosted: Sun Oct 25, 2015 6:32 am
Freehand always worked for me.
PostPosted: Sun Oct 25, 2015 8:07 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
A brad point bit pretty much solves the "wandering" problem, but can be tricky to find in the really small diameters. LMI carries small sizes at reasonable price.
PostPosted: Sun Oct 25, 2015 8:53 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Anyone seen this at the 4:20 point?
I'm not a luthier.
PostPosted: Sun Oct 25, 2015 9:27 am
Marking out with an awl first can save a lot of mistakes. I do it marking out for tuners, dots on the face of the fingerboard. bridge pins, and end pin as well.
Brent
PostPosted: Sun Oct 25, 2015 9:39 am
I use the little pointed scribe StewMac sells for inlay work as a marking awl and have the small LMI brad tipped bits. That has pretty much solved the wandering problem.
PostPosted: Sun Oct 25, 2015 9:32 pm
After having these on my list for years and messing around with random bits here and there, I finally upped my drill bit game a few months ago. These are available in sets and individually, also in imperial and metric.
HSS Brad Point Bits
HSS Twist Drill Bits
I picked up the set of 7 brad points, 10mm (for tuners), along with 3/32", 7/64", 9/64", 5/32" to cover all of the common screw sizes, and a few sizes in twist.
They're incredible. Sharp to the point that I handle them with care just so I don't slice myself. Highly recommended.
PostPosted: Sun Oct 25, 2015 10:56 pm
I do it just like Terence. And Tom apparently! Seems like good company :)
Burton
Brookline, MA.
PostPosted: Mon Oct 26, 2015 6:24 am
Yep
PostPosted: Mon Oct 26, 2015 8:31 am
I do it the same way Terrence, et al, as well but have never thought of that simple little tape trick. Thanks for the tip!
PostPosted: Mon Oct 26, 2015 10:28 am
First name: Roger
State: Oklahoma
I mark mine after the board is glued to the neck but before the neck is carved. I came up with this little jig, and it solved all my problems.
PostPosted: Tue Oct 27, 2015 12:39 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Zip/Postal Code: 37355
I do it like Haans
PostPosted: Tue Oct 27, 2015 1:54 pm
First name: D
Last Name: S
I eyeball the location and poke with an ice pick.
Then drill with a small palm sized cordless drill.
wah
Wah-wah-wah-wah
Wah
PostPosted: Wed Oct 28, 2015 6:57 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Awl, #1 center drill, wire gauge drill.
https://www.carbidedepot.com/formulas-centerdrills.htm
IMHO, center drills are very handy for the times you need accurate placement of holes. I use a #2 to drill bridges and a #2 or #3 to drill pegheads.
PostPosted: Wed Oct 28, 2015 7:19 am
John, Are you using the center drills in a hand drill? I use these on my lathe but have never tried using them by hand. Guess I could just try it.
PostPosted: Wed Oct 28, 2015 6:26 pm
Last Name: Arnold
City: Newport
Sure. Hand drill, lathe, drill press....it's all good.
These users thanked the author John Arnold for the post: SteveSmith (Wed Oct 28, 2015 7:30 pm)
Users browsing this forum: No registered users and 39 guests
